The Journeys of Darla ....
Old 02-14-2022, 09:46 PM
MyFavRk's Avatar
MyFavRk
MyFavRk is offline
Received 6,481 Likes on 3,902 Posts
Thanks , I'll be sure to add that to my list . I'm pretty sure my bud , who I rode with to Jasper the first time , told me about it , we just didn't get there . I think we're going back to Jasper after I get back with my wife , that or Nelson .
The following 2 users liked this post by MyFavRk:
CanadianRocky (02-15-2022), Dynamick (02-14-2022)
  #3152
Old 02-20-2022, 04:28 PM
CanadianRocky's Avatar
CanadianRocky
CanadianRocky is offline
Received 21,700 Likes on 9,543 Posts
well… I am back home in Langley… That was a long four weeks I was up in Cranbrook… Working seven days a week almost… Nice to be home… And we definitely have some motorcycle weather coming… So I went downstairs and started up the bike, and tomorrow I’m gonna go for a ride…
Looks like motorcycle weather to me…
… Started up nice, but the heated grips don’t work… Hope it’s just a fuse.
The following 2 users liked this post by CanadianRocky:
jeffro09 (02-21-2022), Steve Mac (02-24-2022)
  #3153
Old 02-20-2022, 05:43 PM
missionwop's Avatar
missionwop
missionwop is offline
Cycle the ignition a couple times. My last 2 bikes did the same.
CanadianRocky (02-20-2022)
  #3154
Old 02-20-2022, 05:55 PM
missionwop's Avatar
missionwop
If you need to get it serviced pm me. I will let you know here to go and where not to go. Don't know if my last response got thru but i had the same issue on 2 of my bikes and just recycled the ignition a couple of times and the heated grips would work again.
  #3155
Old 02-20-2022, 05:56 PM
CanadianRocky
I will give it a try… I’d also run a code on it to see if there’s anything
  #3156
Old 02-21-2022, 11:56 AM
Vernal's Avatar
Vernal
Vernal is offline
Received 7,575 Likes on 1,969 Posts
The P&A fuse powers the heated grips through the P&A relay. If you have a volt meter or test light check to see if you have power at the battery tender connector, 12 V means the fuse is good. If you have power at the front power outlet, looks like a cigarette lighter, the relay is good and so is the circuit up to the grips connector. I had the same problem and twisting the grip control helped but I finally replaced them with OEM.
  #3157
Old 02-21-2022, 12:02 PM
CanadianRocky
Thanks Bill... I think I have power to the cigarette lighter in the fairing... I will check it out... I have also had a few issues with the plug in the right grip... I will look at that closer also... the grips where working last fall, but then just stopped on the last ride of the year... I have not looked at it that close yet to see if it is something i can fix... thanks for the schematics... I will print them out on my colour printer today...
  #3158
Old 02-21-2022, 01:16 PM
CanadianRocky
Thanks Bill... i got the PDF... that is one long read... lol...
  #3159
Old 02-21-2022, 01:31 PM
jeffro09's Avatar
jeffro09
jeffro09 is offline
Received 3,461 Likes on 1,313 Posts
If our roads weren't covered in salt I'd start up my Limited today and take a spin. I need some therapy!
CanadianRocky (02-21-2022)
  #3160
Old 02-21-2022, 03:30 PM
CanadianRocky
Fixed... I have had this pop up before, and was hoping it was the same thing... the plug on the right grip had become detached... and all i had to do was plug it back in... but for anyone who has had to do it before will tell, you it is a bit of a pain in the butt... very small plug, you need a pair of needle nose plyers, and it is almost imposible to see the end you need to plug it into... so it took a bit of pissing around... but there is now heat on the grips... and I checked out the heated vest at the same time, and it is working also... so a nice toasty ride... I have to do some family chores now, so I will go out tomorrow... Sunny until the weekend... cool, but it should be decent with the heat working...
jeffro09 (02-21-2022), Vernal (02-21-2022)
Quick Reply: The Journeys of Darla ....
