No coolant? Cause stall?
Hello all
Brand new Nightster here with a whopping 20 miles (all back roads). Today while doing some low gear practice runs on start/stop I had some stalling issues. And normally the stall wouldn’t even come at full release, but at about “4”. Previously I didn’t have issues and suddenly today it became consistent. The same time my bike began to have the high temp gauge light on. Signifying over heating. Keep in mind this is 10 minutes into just basic 1st gear stop and starts and a 65 degree day.
I went home and even though it was a brand new bike I checked my coolant. It was completely dry! No coolant at all inside and the min/max dip was bone dry. Obviously I know where my overheat came from. I have since filled the coolant and verified it is where it should be.
I am just curious on if such an issue could cause more stalls on take off than normal, or if that would not impact a stall. Trying to figure out if I was screwing up still or if this was a part of it.
‘Thanks for any input. (And nice quality HD! Deliver a brand new liquid cooled bike with no coolant?!).
Also, in road mode should this bike have the ability to take off from a stop with just clutch release and no throttle? Today even that was stalling which I found odd. Before it worked fine.
Marsikus (11-02-2022)
Received 4,898 Likes
touchdown (11-02-2022)
You need to get the bike back to the dealer ASAP.
The only thing I would say though is regardless of age and mileage what is in the owner's manual? Some pre ride checks and post ride checks are listed that you ought to do be doing.
Many Pan Ams were delivered with slightly less coolant in the resi than spec resulting in dry dipsticks when checked. Not low enough to cause damage. Mine was one, took just a splash of distilled water to correct. I can't imagine your bike was anywhere close to hot enough to cause it to tighten up to the point of being stall prone. I agree you should see your dealer but I don't think you've done major damage.
US66harley
05-11-2011 05:05 PM
