Product Reviews Review various motorcycle products you have used.
Factory "frenched"/hooded headlight trim ring
Old 06-26-2005 | 12:29 AM
traveler's Avatar
traveler
Default Factory "frenched"/hooded headlight trim ring
Hey guys,
Today I installed the headlight trim ring that you can get at the dealer, (mine was for a DYNA, but the others SHOULD be the same...) that gives your headlight the "frenched" or hooded look. Cost is $30 bucks, and the quality is of course excellent. Very easy to do. Just need a small to medium phillips screwdriver, and PATIENCE!!!! When removing the old one, you have to rotate the ring so that the split part is up on top, and then you can carefully pull/peel it off. The new one just goes right on, and has a rubber gasket that is inside of it to make it a tight and professional fit. Definitely recommend, and makes the whole front of the bike look better!
P.S. The package says "Multi-Fit" so as long as your headlight diameter is the same, it SHOULD work. I believe they offer them in other sizes for the other bikes as well....
joe
Old 06-26-2005 | 10:36 AM
JBBOOKS's Avatar
JBBOOKS
Default RE: Factory "frenched"/hooded headlight trim ring
They do look sharp. On my list of things to do. Glad to hear they go on easily.
Now post a pic, please!
Old 06-26-2005 | 11:27 AM
HDF Tech's Avatar
HDF Tech
I did find a pic with it on
[IMG]local://upfiles/2318/F2331A65D1034537B426C3E427A8A81A.jpg[/IMG]
Old 06-26-2005 | 01:37 PM
traveler's Avatar
traveler
ORIGINAL: JBBOOKS
Hi,
I'm working on getting some pictures up!
joe
paulmj
2018+ Softail Models
06-18-2019 11:35 AM
civilbob
07-09-2013 10:59 PM
DrPlastic
02-06-2010 07:56 PM
anubisss
10-19-2009 07:51 PM
traveler
06-26-2005 12:31 PM
Quick Reply: Factory "frenched"/hooded headlight trim ring
