McCuff No Spill Gas Fill ????
RE: McCuff No Spill Gas Fill ????
This \\;thing actually WORKS!!! \\; Key is to make sure the hole in the tip of the fuel nozzle ( you have to \\;really look for it)  \\;is PAST the end of the McCuff......and dont be tempted to raise UP the nozzle once you've started pumping. We found if you depressed the nozzle handle so the gas is flowing out at about at half speed, once it clicks off, you're tank is filled to the brim, with \\;no spills, no splash back, no gas on your tank or hands. \\;
Lke Hawg03 says, try filling your bike with the new pump collars. Blocks your entire view of your tank opening, and shuts off way too early. McCuff fits over the collar and tops off your tank woth one squeeze....not the \\;typical squeeze and splash, squeeze and splash, then wipe off and smell
