Product Reviews Review various motorcycle products you have used.
need good wheel cleaner
Old 03-03-2006 | 12:46 AM
wildbill13's Avatar
wildbill13
6th Gear
Default need good wheel cleaner
hey all, i have an '03 hugger with the original cast aluminum wheels and i cant find anything to get them clean since they are so porus. does anyone have some suggestions?
Old 03-03-2006 | 11:28 AM
CHEYENNE's Avatar
CHEYENNE
Default RE: need good wheel cleaner
I wish I knew the name, but you can get just about anywhere and it's a bright green colored cleaner for rims comes in clear spray bottle in auto department..No not simple Green either..LOL
When I used to work at a car wash we used it and it works wonders.
Old 03-03-2006 | 06:34 PM
breaknbad's Avatar
breaknbad
Buddy of mine uses oven cleaner.
The spray on kind. It works great. He has rough finish on his rims.
Other than that a good wheel cleaner.
I kept mine protected so they never got stained.
David
Old 03-04-2006 | 03:10 PM
bobcowan's Avatar
bobcowan
If the dirt and grim is down in to the alum, you may not be able to get it completly clean. I use Maguire's on polished alum car wheels. That seems to work pretty well.
Old 03-05-2006 | 11:11 PM
Toytech's Avatar
Toytech
Griots Garage, www.griotsgarage.com Seems to be the Place for the guy that needs everything to detail his/her ride. The wheel cleaner they sell works.
Joe
Old 03-05-2006 | 11:26 PM
JSW's Avatar
JSW
Nevr Dull. Will do the job. Its a bit messy on your fingers and takes some elbow grease, but it works. I have those wheels also and it always gets the brake dust and grime off. You can find it at any auto store or even Walmart.
Old 03-14-2006 | 08:02 PM
ToadKing's Avatar
ToadKing
6th Gear
Use "Oil Eater", available at Costco and most auto supply's. Mix with water @ 30% Eater and 70% water, stay away from painted sufaces. Spray on, brush, rinse off, repeat. Do not let this stuff set. it is powerful.
Old 03-16-2006 | 10:33 AM
cgall66's Avatar
cgall66
S100 wheel cleaner works good, but for my solid rear wheel I found that usin Spray Nine and my steamer work the best.
F.B.I. Wideglide
2014-2023 Touring Models
19
09-25-2015 06:07 AM
RoadKing_Bob
04-30-2014 01:33 PM
HD101st
04-21-2012 09:45 PM
Slim_B_Kool
03-28-2011 10:22 PM
masterblaster
12-15-2010 11:15 AM
Quick Reply: need good wheel cleaner
