100% oil change
100% oil change
Any 1 else use the Scavanger Total oil change kit?? I've been use'n 1 now for 2yrs. on both my TC & wife's 1200. Best investment ( 1 of ) that money can buy. Rouge Choppers has videos & distributes them.Got mine from R&R Cycle in Manchester,NH.[8D] Any comments??
RE: 100% oil change
I believe this is just another way to make money. Not that that is a bad thing. But, really, the amount of "dirty oil" will not harm the motor since you are using a new filter which will clean it up any way. Save the money on the scavenger and buy high quality synthetic oil; your motor will run smoother and longer. BTW, BMW cars typically go for over 150-200,000 miles; using synthetic oil and no scavenging system. MHO
RE: 100% oil change
If you've got nearly a quart laying in the sump of your TC, you've got problems. There should be no more than about 8 oz or so in there. If there is more, you likely will be experience power loss from flywheels dragging. To fix it, you will need to be looking for leaking o-rings behind the cam support plate.
RE: 100% oil change
If your TC says it holds 4 quarts with the filter and you drain your oil and refill, you are going to have almost a quart of new oil left over if indeed there is that much oil left in the sump. I have never had that problem. 4 quarts or 3 quarts or 5 quarts depending on the bike including the vrod is what they always took. You know, in the end, if it makes you feel "gooder" than I say do it!
wscott
01-14-2016 06:55 PM
Road_Clam
Oil Archive (no new posts)
31
06-20-2012 03:50 PM
