KURYAKYN plug and play Run-Turn-Brake module and Red LED Converion
Got the KURY RUN-TURN-brake module and Red LED conversion lenses for the wife for christmas and it was too easy to install and works great even has a flasher when you aply the brake. It flashes them 3 times thens goes solid.
This is on the duece
1. Pull the seat
2. 3/8" socket and pull the neg wire off the frame
3. Unplug the stock rear light harness where it goes into the fender
4. Put a little die electric grease(came in kit) on the new kury plugs and stock plugs
5. Plug in the KURY harness to the stock wiring(perfect fit)
6. Plug the load equalizer in the kit to the module
7. Route the wires neatly over and around the the fuse/relay box and battery
8. Replace NEG wire and seat
9. Pop off rear blinker lenses and pull out bulbs
10. Put some dieelectric grease on the new socket plug for led board/lense
11. Use a flat tip screwdriver and install power socket (the same as replacing a bulb)
12. Turn the board a little to curl the wires in and verify the area with a notch on the board/lenses is in the down position and pop the lense/boards in(it is a tight fit but you will get a click once they are in).
13. Turn the key on and verify run lights in the rear, hit the HAZ and verify their function, then left and right turn, then the brake.
Enjoy and hear people talk about them when you drive up to the local bike meet....
1. Pull the seat
RE: KURYAKYN plug and play Run-Turn-Brake module and Red LED Converion
I have the Kuryakyn Panacea Deluxe laydown tailight w/blue dot along with the smoked front turn signals and red rear turn signals. My tailight flashes too (3 times) and I have the turn signal buildt into the tailight. The front and rear turn signals act as running lights too and the rear turn signals flash along with the brake light. Man they are cool and very easy to install. I got mine last summer during the Group Buy from M&M for 20% off.
[sm=biker2.gif]
[sm=biker2.gif]
I know I posted this on another thread, but BikeTronics stuff is excellent!
http://www.biketron.com/item.html?PRID=1112045
