REVIEW=Revtech DFO (TFI)
I have a Revtech DFO (also under the name of TFI) and couldn't be happier. The product is a snap to install and is half the price of a PC. There is nothing wrong with having a PC -- I'm just here touting the alternative (I've had both). I had one question for them and called the toll free number. The customer service rep connected me to tech support and that person was the inventor and owner of the company. He clearup my concern and explained in detail the difference between the two products (he should know, he also invented the PC earlier). His name is Dobeck (of Dobeck Preformance) -- a good guy with a good product line in my opnion.
RE: Revtech DFO
No need to remove the tank, you can just unbolt it and raise the rear up a few inches and work like that to remove the injector clips and also unlatch the wire retainer that is under the rear portion of the tank to insert the harness into it to protect it.
The DIY forum has some input on it, at the bottom of the page is the install instructions.
https://www.hdforums.com/forumid_247/tt.htm
RE: Revtech DFO
I feel like an idiot but I can find the two injector plugs but for the life of me can't figure out where the other two plugs go. I see no other matching stock plugs. The instruction say nothing about where they go. I have an 05 Road King and acquired the revtech dfo number 601203. Did I get the wrong one?
Any help will be appreciated
Thanks, Sam
Thanks, Sam
RE: Revtech DFO
Got it done! I used the suggested settings and the decel popping stopped. On taking off I would always feel a catch while letting the clutch out. Not anymore. Takes off very smooth and can tell that acceleration is better all through the gears. The exhaust sounds and feels a deeper rumble. Had I not found this forum I would have never known the difference.
Thanks to all of you.
RE: Revtech DFO
I couldn't answer your question in your earlier post because I spliced mine directly to the wires and not through the plugs. So I didn't have to do anything with the gas tank. Just removed the seat and right side cover. When I saw TC step in to help I knew you were in good hands.
That catch you used to feel was an off idle stumble from a lean mixture. No more! My bike worked better from bottom to top after the install -- without spending the time or money for a Dyno tune.
Glad you're happy with it.
