Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Changing from a 66 tooth to a 70 tooth pulley
Old 03-25-2007, 10:41 PM
FXSTD.AU's Avatar
FXSTD.AU
FXSTD.AU is offline
Default Changing from a 66 tooth to a 70 tooth pulley
I'm installing (or my dealer is installing on my behalf) a set of Arlen Ness rims on a 2007 Deuce. As part of the installation the matching Ness chrome pulley will also be installed, but the stock pulley on the Deuce has 66 teeth whereas the Arlen Ness pully that matches the rims has 70 teeth.
I also need to change the belt to a narrower belt (PN 40655-06), but thats straight forward. Can anyone tell me what if any change to performance this changine over of pullye's willmake?
Would any change be required to the transmission gearing ration to compensate?
My simple understanding is that the larger the tooth count, the quicker it spins ths the higher the revs. A 66 would also have greater power than a 70 tooth (same simle mechanism as a geared bicycle), but would the difference be noticable or determental in any way to the transmission or the engine?
FXSTD.AU
11
04-13-2023 05:00 PM
RussW4
2014-2023 Touring Models
16
02-28-2019 11:31 AM
luvtoride
10-09-2010 05:58 PM
garyw
05-15-2010 09:32 AM
FXSTD.AU
03-28-2007 08:08 AM
Quick Reply: Changing from a 66 tooth to a 70 tooth pulley
