OPEN PRIMARY ON PAN
OPEN PRIMARY ON PAN
I AM CONVERTINGTO AN OPEN PRIMARY ON A 51 PAN.I NEED SOME HELPFUL TIPS. IT'S BEEN AWHILE SINCE I HAD THE CLUTCHAPART AND I NEED TO GET THEREAR SPROCKET OFF WHICH HAS NEVER BEEN OFF.GOT THE FRONT COMP SPROCKET OFF BUT THE BACK IS GIVING ME A PROBLEM.DO I JUST NEED TO BUST OPEN ANOTHER KNUCKLE TO GET IT OFF OR IS THERE AN EASIER WAY???THANKS IN ADVANCE TO ALL WHO ANSWER
RE: OPEN PRIMARY ON PAN
I've got a 64 pan if their the same this should help. If you have the disks out aleady theres the reverse thread nut in the center and then theres 5 sir/cir clips that need to come off each on one of the 5 rods that had the springs on them then it should just be a matter of slipping the belt off of the sprocket. Hope that helps man.
neverdown
06-17-2012 05:47 PM
