2014 Primary Noise?
2014 Primary Noise?
Howdy, I was wondering if anyone else with a 2014 model thinks their primary is noisy? My FLHXS has a pretty significant chatter at certain rpms. Can even hear it over Rineharts barking away. I am guessing it must be something with the compensator. Probably ok but it just seems loud to me from my past experiences with Harleys. Currently running Formula plus in the primary. Thoughts?
I could believe that the chain tensioner needs to get some slack out because on occasion at idle I can hear a spordaic "slap" coming from the primary. It's obviously the chain slapping around. So do you think this will adjust on it's own or should I look to address something?
So if I pull my primary cover to have a look around and with regards to the chain, how much play should it have if it's adjusted right and how do you measure it? Thanks.
Well. .i may have been wrong. There is no posted spec for the auto tensioner free play. Recently someone on another forum pointed out that the springs in the auto tensioner allow an additional 1/2" of movement. So he suggested that 1/4"-3/8" free play is completely normal, for the HD auto tensioner. To measure, you pick a spot on your top chain midway between clutch and compensator, pull down slightly (not much force), then push up the opposite direction. You want to measure that travel distance. Mine barely moved downwards (typical) maybe 1/8" and moved upwards about 1/4". Total movement was 3/8", at that spot. Keep in mind chains have a tight spot which is where you should measure by going in neutral and spinning the rear wheel and checking until you find it. I didn't bother as I had already decided to try out the Hayden M6 tensioner since I'm in there for other upgrades/fixes.
