Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
transmission leak at exhaust bracket
Old 08-30-2013 | 08:41 PM
ronherman's Avatar
ronherman
Default transmission leak at exhaust bracket
I noticed a small oil leak at the exhaust bracket, the 2 Allen bolts came loose and I got some oil leaking out of there. just concerned whether I will need to replace the gasket or just retighten them. I am thinking blue Loctite and maybe some Teflon paste, any suggestion's?
Old 08-31-2013 | 04:09 PM
Popeyejoe's Avatar
Popeyejoe
6th Gear
A common problem with dressers, just tighten the bolts up ( 4 ) have done this for my customers for years with good results. If you don't trust them, pull each bolt out and use thread locker on them and torque them to spec's.
Old 09-03-2013 | 07:31 PM
ronherman's Avatar
ronherman
thanks popeyejoe, I thought there was more to it than that. some times with the bike I tend to think its more complicated than a simple fix! tightened them up and all is fine, thanks again!
SeaClassExpert
02-11-2019 07:43 PM
Dr. Tiki
2014-2023 Touring Models
05-24-2018 04:16 PM
stro1965
03-19-2013 08:52 AM
al baehr
08-30-2010 08:13 PM
Kbore
08-15-2009 01:05 PM
Quick Reply: transmission leak at exhaust bracket
