Wont shift!!!
Wont shift!!!
im new to the site so go easy on me. I have a 83 lowrider shovel. I installed a new clutch cable and now I cant get it to shift into any gear, clutch is moving when I take the cover off and I adjusted the cable to what the last one was. Another weird thing is since I installed the cable now my kicker don't work neither. all I did was install a clutch cable that's it. WTF is going on? and yes everything worked as far as I knew before
Adding to Mike's comment, you might want to readjust your clutch at the adjuster screw and the cable. See link:https://www.hdforums.com/forum/trans...-easy-way.html
Northern Glide
03-03-2013 12:17 PM
2002fxstb
15
12-18-2005 04:23 PM
