Clutch Cable Replacement
If I remember right, the proper adjustment at the clutch set screw is 1/2 to 1 full from seated. All other takeup is done thru the cable.
That will not change no matter how long the cable is, unless its the wrong cable!
Another thing that can happen, if you loosen the clutch adj too much, one or more of the ***** in the thoughout lever can fall out. If that happens, you have to diassemble the right tranny cover and reassemble the lever with ***** in place (use grease).
2 1/2 turns out from seated could cause the above senerio. No amount of cable adj will make up the difference, and there may be ***** (3/8") floating around in the case, not good. fwiw Fastrider 124
00glider
05-20-2006 10:58 PM
