fifth gear seal
fifth gear seal
I have a 2001 FXDWG and I had to replace the fifth gear seal. To do this I had to make a puller to remove a sleeve on the main shaft to get to the seal. The tool worked great however After I installed the seal I used a piece of tubing and a mallet to put the sleeve back and it seams to have pushed the whole main shaft into the transmission about a quarter of an inch. I can probobly use a slide hammer to get the main shaft back to it's proper location but did I screw something up by pushing the shaft in?
Check the below images and you can see what you might have done. You can try the caveman/slide hammer approach and, if it works, go buy a Lotto ticket because you are very lucky. I would be more inclined to tear down enough to inspect all the parts that could have been damaged, replace them and put it back together properly.
Don't use a slide hammer. Pull the clutch actuator cover on the right side of the transmission. Take a plastic dead blow hammer and hit the nyloc nut that retains the mainshaft and you might get lucky. Once the mainshaft is back in place get that rear tire off the ground and have a friend spin it while you shift through the gears manually. If you don't get lucky pull the transmission and send it to me here at Baker and we will rebuild it.
When you beat on a shaft, you are putting a lot of force on the bearing that holds its running position, and also the housing that supports the bearing.
Remove the chrome cover on the right side of the transmission, and make sure the trap door is not damaged in the area of the snap ring.
1/4" seems like a lot.
For the mainshaft to move that much, it would seem that something had to give, either the bearing in the trapdoor, the snap ring, or the lip that supports the snap ring.
+1 I have $5 that says you bent or popped out the snap ring....not hard to do. Don't ask how I know this....
