strange noise
I have 75 fxe here's the problem.. when I first start it and put in gear as I release the clutch it makes an awaful noise.. the noise stops after about 3 foot of travel . I thought it was the front duel disk breaks.. took them off and still makes that noise.. I noticed it only does it when motor is cold, once its all warmed up there's no noise.. has a primary chain and it looks good. The privious owner did have the engine gone thru I have a folder of receipts of all work that has been done over the years , the only other thing I noticedis a slight slip of my clutch at high rpm.... everyone I talk to says live with it, its a shovel...... thank you
