Size of snap clip on clutch lever pivot pin?
So I can get the right size pliers and extra snap clips for the pivot pin on the clutch lever (and do so the first time at the hardware store), does anyone know what size they are? My experience is that the small clips get quickly lost without the right pliers and that's what I want to avoid. Thanks.
ORIGINAL: OneBlackFly
Size is 7/16 external
So you know...I work for KNIPEX
For most of the small Circlips on a Harley you can use pliers with size 0 or 1 tips. For transmission work sizes 1 and 2, Just don't use a small size Circlip pliers on a big Circlip. Even though it fits, using a small pliers on a bigger clip will break the pliers tip off.
At the bottom of this page you will see a chart that will help:
http://www.knipex.com/index.php?id=1...5&groupID=1453
echelon (06-06-2021)
MichiganRider
06-03-2022 02:56 PM
crissguinn
12-28-2008 12:25 PM
