2007 1200 sportster clutch adjustment
Hi everyone and thanks in advance for the help.
I have a 07 1200c, when I put it in 1st gear it makes a loud clang. If I start it in gear it pulls a littl forward so I want to see if adj the clutch will help. When adj the clutch do you back the adj screw out till you fell tension or do you back it out till it stops? And is there anything else that may cause this prob?
Thanks again
Thanks again
Mech883
09-03-2018 03:09 PM
jc15025
10-04-2010 08:16 AM
