Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
here's the problem, I was riding today every thing going fine. I stop to get gas and when I try to start my bike the starter engages and the open primary just spins im lost any ideas. It is a custom bobber with Ultima 113 motor Ultima 6 speed Trans and Ultima open primary. Thanks for any help.
Sounds like no compression. You need spark, fuel, air, and compression. Not trying to insult your intelligence. Pull the plugs and coil wires and put your finger over each hole and crank. It shoud pop your finger off and both cyl should sound the same. Do you have gear drive or chain?
well it looks like the teeth on the sprocket offset collar that go over the crankshaft are stripped. I dont know how that could happen. thanks to everyone for the help.
