5 into 4 case revtech sprocket
i have a revtech 5 into 4 speed case trans i ordered a sprocket for the trans and the one i got for it is stepped or offset this trans apears to be like an early 5 speed like a fxr or flt but in a shovel frame did i order the right part ?or should of it been a flat sprocket? im building the bike from scratch so i dont know want its gotta look like its a 79 FLH with an evo
thanks for the reply yup i found out about the nut hitting the case yesterday ,the ends of the points on the nut was just hitting the inner primary i just filled then on a 45 it clears great now im running a mid 90s fatboy rim ive spaced my rim center and now need a flat sprocket for the rear im using 23/51 tooth
graves1
05-11-2010 08:18 PM
