Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Burnt Smell in the Primary
Old 01-10-2007, 12:53 PM
Nomadic RAM's Avatar
Nomadic RAM
Nomadic RAM is offline
Default Burnt Smell in the Primary
Uh-Oh. Changed the primary oil on my '05 FLHTCUI yesterday and the stench of the oil was terrible. Smells like something died and was burned inside. The oil itself was a dirty dark gray color, but there was very little in the way of metal dust on the magnetic primary drain plug. The bike has 45,000 miles on it and it had 2,500 miles since I last changed the primary oil. I use HD Formula + Transmission/Primary Oil. I have a HD automatic primary chain tensioner which I installed 30,000 miles ago. The bike is stock from the air cleaner to the exhaust.
What's causing the smell? I've got no electrical indications of problems with the stator (yet). Since Christmas I've been riding in the clutch friction zone a good deal following the practice guidelines in "Ride Like a Pro IV," but I've religiously followed the cooling recommendations in the video. Have I cooked the clutch? The bike was running normally before I changed the oil (I've not done a road test yet as the wheels are still off the bike getting new rubber).
What should I do now?
Thanks,
Nomadic RAM
Old 01-10-2007, 01:04 PM
sleepneagle's Avatar
sleepneagle
sleepneagle is offline
Default RE: Burnt Smell in the Primary
burned clutch
Old 01-10-2007, 01:14 PM
JLHOG's Avatar
JLHOG
JLHOG is offline
Burnt Stator, They really stink when they toast!!!
Old 01-10-2007, 01:58 PM
Nomadic RAM
How do I determine if its the stator? If it is a burnt stator anybody know if that would be covered under warranty??
ORIGINAL: sns
Old 01-10-2007, 02:51 PM
Doug's Avatar
Doug
Doug is offline
May be Formula Plus it smells like a fish died in the oil.
Old 01-10-2007, 04:11 PM
JLHOG's Avatar
JLHOG
JLHOG is offline
what is your volt meter reading?
Old 01-10-2007, 10:07 PM
Nomadic RAM
Absolutely normal - 14+volts just like always.
ORIGINAL: sns
Old 01-11-2007, 09:47 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Electrical components really stink when they burn,dont know if thats the problem.
Was the the oil level low when changed out?
Old 01-11-2007, 10:56 AM
JLHOG's Avatar
JLHOG
JLHOG is offline
If you could still smell it days later, you may want to pull the cover and look at the stator. When they burn it really smells bad. If you click on the link in my signature you can see one of mine that cooked.
Old 01-11-2007, 11:47 AM
recross's Avatar
recross
recross is offline
Don't know if there is a way for early warning of the stator going...however I know from experience that when they do go...it's sounds exactly what you're talking about.....would like to know also if there is an early warning sign...sounds like the voltage is aok...I've had mine go while on vacation...there one minute...gone the next......keep us posted..................
BC
Quick Reply: Burnt Smell in the Primary
