Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Screamin Eagle clutch spring nut backed off!
Old 06-07-2012, 12:15 AM
hivoltg's Avatar
hivoltg
hivoltg is offline
Default Screamin Eagle clutch spring nut backed off!
I posted this same question in the touring section here:
https://www.hdforums.com/forum/touri...acked-off.html
but I figured I may get some good info here as well.
I have the Screamin Eagle clutch in my 07 Ultra. I noticed this weekend that it seemed to be slipping in 5th gear. When I got home and allowed the bike to cool, I started to adjust the clutch. When I pulled the derby cover, I noticed that one of the 6 nuts holding the springs to the pressure plate was backed off and only holding on by a single thread. I tightened it back up to the same spec as the other 5 nuts and adjusted the clutch. All is well now, except I'm paranoid that the same thing will happen in the future and I may not get lucky next time and catch it before the nut falls off and all hell breaks loose
Has anyone here had a similar problem?
These 6 nuts seem to be nylock nuts. Why would they back off? Should I replace all of the with new ones? If so, what size are they?
Thanks for all your help
Old 06-06-2024, 10:32 AM
Redpop's Avatar
Redpop
Redpop is offline
3rd Gear
Never had one back off before maybe someone forgot to use some Loctite I would definitely put a little Loctite on it because they don’t torque very tight. I can’t remember right off the top of my head but I think only 75 inch pounds.
Old 06-07-2024, 03:05 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 6,019 Likes on 4,065 Posts
I extended the studs and double nut them..
Old 06-16-2024, 08:43 PM
expertwrenchthrower's Avatar
expertwrenchthrower
expertwrenchthrower is offline
6th Gear
Default This is why I come here
To find the meaning of life. It's patience. I don't understand the double nut nut. Why?
Old 06-16-2024, 09:46 PM
Max Headflow
If you have a problem with a single nut moving on the threaded stud, using 2 nuts can lock them on the stud.
pjpockets
09-27-2014 08:42 PM
SportyPig
04-04-2013 02:31 PM
hivoltg
06-07-2012 11:58 AM
1st 96 ultra
07-29-2011 05:53 AM
Junior Bravo
01-25-2006 04:30 PM
Quick Reply: Screamin Eagle clutch spring nut backed off!
