Aftermarket Ring and Pinion Gear Set
I'm gonna look into purchasing a ring and pinion gear set with the pre 94' ratio or whatever is equivalent. I did some searching on this site and haven't really found any suggestions as far as what brand is good or how many comnpanys out there actually make this set. So my question is what is a good brand to purchase? Any pros or cons? Any links to websites would be nice. The only one I found was the kit from Compu-Fire.
I just chewed up 2 stock pinion gears with probably less than 3-4 hours on the bike. Time to look into somethig else.
RE: Aftermarket Ring and Pinion Gear Set
I'm talking aboutthe pinion gear on the starter. It seems to be a common problem after doing some research.
Like this kit:
http://www.bikersedge.net/eshopprod_...4_GEAR_SET.htm
Like this kit:
Yeah, you really need to be looking in to the real problem. Something isn't aligned correctly somewhere. On my '97, I never changed them in 45K miles. It was also my daily commuter bike. If you just replace the gears, you'll be doing it again in a week.
the compu-fire kit is a god one but like the other post tearing up that gear is not a real problem you most have another problem and are you sure you tore the gear up if the starter clutch goes bad it sounds alot like grinding gears when you try to start it so check it first if it is the starter clutch the all ***** one is a really nice peice
Hmmm maybe it is something else tha's not aligned correctly? I just replaced the starter about 4 weeks ago with an all ***** starter because my stock starter took a crap. I put the starter back on just like I took the old one off. But I'll look into it some more.
Thanks for your help
ORIGINAL: bobcowan
That's the problem. The starter is sitting about 1-2mm too low. Just low enough to cause the gears to bind.
I love trial and error...[sm=headbang.gif]
revnrob
02-25-2014 03:48 PM
JustDave71
07-14-2010 09:15 AM
