Who's Using Race-less Inner Primary Bearing?
The seal doesn't come with bearing I bought, thus I used the retaining compound. I also took another look at the bearing, its not working properly. There's a tight spot, and a krinkle in seal on inside primary side. I've ordered another bearing, asked about seal at HD dealer. It's a sealed bearing was their answer. This is 1985 rotary top (cowpie) tranny. The sleeve is gone, so you're right, the old outside seal is to small. Where can I get the seal you refer to? Part # etc? I thought about an o ring on the shaft at the bearing, but nothing to hold it in place. Where do you install the seal you mention? I've not seen the seal, so I'm asking?
But I'm not familiar with your tranny so I would suggest you mike your shaft surface first to make sure it is likely to seal up the shaft. I miked the seal prior to install (to make sure it would work!) and the i.d. of the TTO seal is 0.973". The o.d. of that seal miked at 2.05" and width 0.310".
The seal presses into the inner primary case just like the OEM seal did and in same location. Just outboard of the retaining clip that holds the upgrade bearing in place. I went with the All *****, and it is wider than the Baker so I only had one retaining clip which is outboard of the bearing. Bearing is pressed against the clip from inboard.
Best o luck!
Yes, I was concerned that the bearing would still seep oil between the shaft and the bearing. The primary vents throught the transmission mainshaft, so there shouldnt be any pressure in there, but I know how my luck goes sometimes. After more studying, and closer scrutiny of the bearing I had installed, the bearing had a problem. It was kinked, and would catch when you tried to roll it, so, into the trash it went. Im going to try it once more, but, Im going to remove the inside the primary seal, thus the bearing wont dry out, just a personal thing, I dont recommend anyone do that. Also, Im going to put a 25X52X7 metric double lip seal seal back in the primary. This will seal the mainshaft since the race is gone with the new upgraded bearing. Baker has this kit, but, the local dealer only sells the bearing, as well as JP Cycles when buying the bearing, just ordered the seal a few minutes ago, had the bearing pressed in by the HD dealer today, and started to put the primary on, but just couldnt bring myself to do it without some sort of seal. Got my fingers crossed.
teeroy_
13
11-04-2020 05:30 PM
FroggyFatBoy
47
06-07-2015 05:57 AM
