Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
starting problems "please help"
Old 12-31-2006 | 10:12 PM
hd2007's Avatar
hd2007
Default RE: starting problems "please help"
I have done several tranny swaps it could be many things , I know the jack shaft is year specific they changed it in 94 , make sure you have the right part . Whenever you do something like this you have to pick a model year and get the right parts. Like said in a earler post pull the plugs and start there , does it turn over correctly ? check your main ground , engine alignment is very important ,I have had to run larger ground wires in the past .Start there and keep us posted.
Old 01-01-2007 | 10:15 AM
1flhtk4me's Avatar
1flhtk4me
ORIGINAL: blown87
keep in mind that iam not doing this work myslef, a very very very reputable company in the business which i dont want to name yet installed the transmission and primary kit along with hydrullaic clutch. at this point they are speechless and dont know what to do. i have alot of money in this bike
Not that this will fix the problem,but if the shop is so "very,very,very reputable"why cant they find the problem???
Old 01-01-2007 | 11:21 AM
brian1's Avatar
brian1
One more thing to check is the jackshaft support (boss) in the primary cover. There were different primary covers made which will bolt up fine but the boss in the cover for the jackshaft support are different sizes. You could have a mismatch here meaning a larger bushing in the cover than the jackshaft size that would allow the jackshaft too much side movement, could apply here from what you describe.
jeffmyers6876
General Topics/Tech Tips
01-01-2017 03:50 PM
Crazyelsken
11-22-2016 09:13 AM
Turc1202
05-28-2013 01:47 AM
jfm5
08-31-2008 03:29 PM
113fatboy
06-03-2008 10:17 PM
Quick Reply: starting problems "please help"
