Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Compensator nut and clutch nut torque for 2007flhx
Old 12-25-2011, 07:18 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,966 Likes on 4,159 Posts
Used 165 while back. Insured all threads were clean and primed and used the red permanent grade loctite. That worked. I tried the torque plus the degree thing this time and realized at least on my older design (04) comp that when you mark the position on it, it tends to also move when nut is turned making that method totally unsuitable. (cover with springs slips) Guess you are suppose to mark it way up on face of primary cover?
Old 12-26-2011, 10:11 AM
dgkurilkojr's Avatar
dgkurilkojr
dgkurilkojr is offline
Originally Posted by heybaylor
the New bolt ( actually a nut) come with locktite already in the nut.
If you cleaned the threads on the nut and the crank well and applied red locktite..you should be ok with re-using ..( lots of bikes out there that have used the nut several times).
the manual is a CYA statement regarding the one time only use.
disclaimer : this is only my opinion and past experiance.
I actually just re-used the same one when i had to take off my inner and outter primary to install forward controls on my bob....a couple weeks later the bike wasnt wanting to start and i couldnt figure out what it was so i took it to the dealer bc it is still under warranty. the reason was the compensator bolt came loose and the plates were slipping. they COULD have voided the warranty if they wanted too. luckily the group of guys up at the local shop are all a really good bunch of guys and took care of it for me and got the warranty to cover. not saying yours will come loose just what happened in my situation. that bolt really is a lot of stress
Old 05-06-2012, 11:52 PM
Bangs auto sounds and Harley custom's Avatar
Bangs auto sounds and Harley custom is offline
Stage II
What size is compensator nut
Old 05-07-2012, 08:53 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
13/16"
ral819
Milwaukee Eight (M8)
08-13-2018 04:09 PM
Jersey Drew
2014-2023 Touring Models
05-10-2017 04:27 PM
getblended
02-15-2015 11:42 AM
hoytheld
06-11-2009 07:09 PM
sniper77
11-18-2007 06:48 PM
Quick Reply: Compensator nut and clutch nut torque for 2007flhx
