Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
belt drive
Old 07-21-2005, 12:40 AM
riverman's Avatar
riverman
riverman is offline
Default belt drive
So how many miles can I expect out of this belt? Mine is on a 98 883 w/21K miles. It looks ok. No cracks. No obvious wear patterns. Taking it to stugis. Should a pack a spare? I have not owned the bike long. From all I have been into the maintenance has been decent, but I have no documentation as to any particular shop (HD or otherwise) that did it. I suspect prior owner (original owner) did his own. Should it go 30K, 40K, 50K? I don't really want to be shopping for a belt along the interstate in South Dakota.
Old 07-21-2005, 12:43 AM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default RE: belt drive
I don't think they have an expiration on them, I really think the style of riding has a lot to do with it more than anything else. Stone damage usually takes it's toll and dirt roads as well as gravel, but all in all , they get some great miles out most of them.
Old 07-21-2005, 01:08 AM
John TN's Avatar
John TN
John TN is offline
Big Kahuna HDF Member
TC covered it pretty well, I will add proper slack/tension adjustment can make a difference as well, on the life of the belt. It still amazes me that they hold up like they do, I remember the first time I saw one, I thought to myself that won't last long, boy was I wrong.
John TN
Old 07-21-2005, 01:44 AM
1200c's Avatar
1200c
1200c is offline
You can get 30K out of a good chain. You should expect 70-100K out of a belt. Belts are called "maintenance-free" for a good reason. The one thing that can kill a belt quickly is gravel. If you get a rock stuck in there, then it can shred within a few hours.
Old 07-21-2005, 09:26 PM
riverman's Avatar
riverman
riverman is offline
Thanks for the info. that makes me feel a little better. I'll check the tension again this weekend. First one of these new fangled belt things i've had.
Old 07-21-2005, 09:34 PM
mikeisglidn's Avatar
mikeisglidn
mikeisglidn is offline
if your going to pack a spare belt youll need to pack a jack, and a crap load of spare tools!!
Old 07-22-2005, 12:23 PM
billnourse's Avatar
billnourse
billnourse is offline
I got about 65,000 out of the Roadking. Wife had 47,000 on the Lowrider when we sold it.
If you are going to carry a spare belt, it would just about have to be a temporary. HD has them. To do a belt change on the road will require a bunch of tools. More than you could carry on a Sportster with any degree of convience.
Regards,
Bill
Old 07-22-2005, 10:40 PM
riverman's Avatar
riverman
riverman is offline
I found one on ebay for 20 bucks and thought I would keep it around for a spare. Couple of the guys I'm riding with are pulling trailers, so we will have some tools. But, based on what I am hearing i don't think I am going to worry about it. The belt has 21K on it and looks fine. My prior bike had a chain so I just was not sure what to expect out of this deal. Thanks for all the input. jb
Old 07-23-2005, 01:21 AM
Markcuda's Avatar
Markcuda
Markcuda is offline
I'm still on my first one
Old 07-23-2005, 03:30 AM
riverman's Avatar
riverman
riverman is offline
my hat is off to you my friend. That is some serious riding.
Quick Reply: belt drive
