Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Have a 06 wide glide and noticed a clicking noise coming from the primary. Almost sounds like plastic on metal and no particular pattern to the clicking noise. Is this normal? Bike has 4,500 on it. Thought it might be the primary chain tensioner?
Had a friend that had the same sound. Pulled the cover, the comp. nut and the clutch hub nut was loose. Took it apart,added locktite,re-torqued. noise gone.
im thinking this is normal i have an07 night train and if i let of and get back on the throttle it makes a tick noise from the primary i was told that its just the slack in the chain tighting up
