Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I recently had a issue with the taorxs bolts on Derby cover and switched to Hex Head stainless bolts... The Stock bolts had a fixed washer, my question is should I stick with flat washers or get the split kind to lock the bolts in place>
Thanks
John {Bushy}
had the stock one, replaced them with better ones, dealers did a service and could not get them off.. finally got them off and vowed to never use torxs again
