Warm primary
Warm primary
I just purchased a 2008 Ultra with16000 miles, After a hundred miles the primary felt extremely hot, I went to pull the cover when I got home and the top bolt has been rounded out and I cannot pull it off, Any thoughts on getting it off and how hot does the primary cover usually get?
And I believe there is no other way to check the fluid than pull the cover right?
Yes, the primary gets quite warm...but extremely hot might be a different issue.
Good luck!
Problem solved I believe we all over complicated the solution to the rounded bolts. I took a 1/8 inch drill bit drilled a pilot hole then took a slightly larger one to it then again a slightly larger one drilled the head off and the took the cover off, and with a pair of pliers backed the stud out.
Thanks for all the help.
