Transmission Plug
Transmission Plug
I have an 07 RK standard (yes it makes THE noises) and had the 1000 service done by dealer instead of me... Now because of the transmission noise I wanted to TRY some AMSOIL HD in the TRansbox. So when I went to drain it I noticed the plug was like real sticky when trying to pull it out... finally get it out and I find the plug has no o-ring on it and it was wrapped in teflon prior to the previous installation. No mind you it did not leak, but this was done by the dealer. I looked at my service manual and I know because I do all the maintenance on my 06 Dyna w/ the 6 speed tranny and they all have/show the o-ring on the drain plug and have no mention of teflon on the plug.
Now I realise this is not really THAT big of a deal. But after spending 320 bucks, IT F'ing pisses me off that they aren't doing it by the book and are rigging ****. I can only imagine what other cr@p they do for shortcuts etc... The guy ran out of o-rings most likely and was to lazy to get some... OR MAYBE there is a super secret squirrel technical bulletin for HD tech eyes only out that there is a problem with the tranny's leaking and to use teflon on the plugs rant is over (thanks)
Regardless, has anyone else had dealer service do this?
RE: Transmission Plug
First off, check and see if it's a pipe plug instead of an O-ring plug. If one end is slightly smaller than the other, it's a pipe plug. Then no O-ring is used, and teflon paste (not tape) is a must.
Sometimes the service manual is wrong, and doesn't keep up with new changes. Surprise!
