Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Engine Swap
Old 03-31-2011 | 04:06 PM
jsvec2000's Avatar
jsvec2000
Stage II
Default Engine Swap
I have a 2006 flhx fuel injected and I have the chance to buy a 2008 flhx motor and transmisson. How much difference is there in changing out my 88 ci for the 2008 set up 96 ci Will i need to purchase to do the swapping
Old 03-31-2011 | 05:17 PM
grbrown's Avatar
grbrown
Strange question! For relatively little outlay you can convert your TC88 to a 95" or even larger, for much less than the other engine/trans is likely to cost. If you want to improve the performance of your 06 there is much you can do with the cash that's burning away in your pocket!
dh2683
07-09-2015 09:47 PM
Rapid99
08-01-2013 05:19 AM
jsvec2000
Exhaust System Topics
04-01-2011 11:30 AM
Riser
02-22-2011 08:12 PM
jimomatic
01-25-2010 11:20 AM
