Clutch problem
Look for that spring that fell in the floor when you removed the primary and or derby cover. It's a small spring that inserts over the jam nut where the adjuster screw is. If thats not it, be sure one or more of the 3 steel ***** for the ramp assembly where the clutch cable connects became dislodged from the groove they ride in. After checking that, remember the adjuster screw turns counter clockwise to adjust the clutch. Screw it out until (ccw) until resistance is felt then back off 1/4 turn. One of these three will fix your problem. Stroker
HDF Tech
217
09-07-2023 09:07 AM
Bear09
02-17-2011 02:57 AM
dgreer169
07-11-2009 06:50 PM
