Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Keep the bolts in order, as at least on mine which is an older pre-unit, some of the bolts are different lengths. Also try to save from damaging the gasket if you want to re-use it.
