HELP! inner primary is cracked
i have noticed a leak that has gotten much worse over the past few months. after finaly getting all the oil (or primary fluid) off the inner cover i noticed a crack that th previous owner had welded up. it is at the very front of the inner primary and is now leaking at a fast rate. i took i to a loca shop and they quoted me $525 t replace the gasket on the inner an the valve cover gaskets. i didnt find out tll i got home that the inner was actually cracked.
i have a service manual but it is not very in depth about what needs to be done to remove the inner primary cover and replace it. i am a pretty good mechanic but i have never torn into the primary before. do i need any special tools or can it get everything out with normal automotive tools?
renlan
05-08-2023 09:29 AM
