Clutch - broken cable but not engaged.
Here goes, out riding this weekend coming down a good slope with the clutch pulled in when suddenly I feel nothing at my clutch lever. First thought clutch cable snapped, second thought why didn't the clutch engage. I haven't gotten a chance to look at anything yet but just did the primary oil, primary chain adjustment and clutch adjustment probably less than 50 miles ago. Any ideas before I go in would be appreciated.
94 FXLR
94 FXLR
Another update
Here's where I am the adjustment screw is welded to another rod that is pretty tore up but it came out of the clutch side with a little coaxing. On the tranny side the oil slinger and rest of the push rod came right out easily. I found a washer looking piece, maybe THRUST RACE - BEARING or/and CLUTCH THRUST BEARING
I've been reading about in the posts, laying in the bottom of the tranmission cover. The snap ring is no where to be seen. Also as a kicker when I removed the transmission dipstick the dipstick part broke off and was also in the bottom of the transmission cover.
Smoothie54
05-04-2018 02:30 PM
