Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Dyna clutch help
Old 02-06-2011 | 06:51 PM
wnmech's Avatar
wnmech
Stage IV
Default Dyna clutch help
This is my first post and first harley. I just bought a 2003 dyna. The previous owner had drag bar installed and I went back to the factory mini ape hangers. I was required to replace the clutch cable. The clutch did not slip prior to replacing the cable. I had to remove the side plate on the transmission cable to install the new cable. I just hooked it up and closed the cavity and adjusted the clutch play and now it slips under hard power. I have tried adjusting the clutch cable both ways no difference. Is there a trick I missed when I hooked the cable up to the transmission. Thanks for any help.
Old 02-06-2011 | 06:55 PM
dawg's Avatar
dawg
Welcome. I would take the derby cover and do a full clutch adjustment, then adjust the cable.
Old 02-07-2011 | 12:55 PM
wnmech's Avatar
wnmech
Stage IV
Thanks for the quick reply I will try that after work today
Got home from work and adjusted per DAWG's instructions and bike runs perfect. Thanks for the quick help.
bljones2007
08-15-2015 07:52 AM
da-lou
03-12-2013 10:52 PM
Northern Glide
03-03-2013 12:17 PM
joebotics
Sportster Parts
07-16-2011 07:15 AM
barnzee
07-04-2011 11:40 AM
Quick Reply: Dyna clutch help
