Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I really like the look of the primary exposed, so my question is can I just remove my primary cover and its that easy? Or is there more too it then that?? I just dont want to take it off and then **** stuck with more then I expected....
Difficult to keep the oil in with the cover off. But you can install a dry belt driven primary if you have the desire. If you go that route it is recommended you keep your fingers & toes outa there while it is running.
