Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Cam chain tensioner Noise?
Old 09-30-2006 | 10:45 PM
Fatboy2's Avatar
Fatboy2
Default Cam chain tensioner Noise?
This horse has probably been beat to death but has anyone noticed any noise with worn or bad Cam chain tensioners.
Old 10-01-2006 | 01:30 AM
xxxflhrci's Avatar
xxxflhrci
Default RE: Cam chain tensioner Noise?
By the time you hear noise, you have metal on metal. That's too late. Pull the cover off and have a peek.
Old 10-01-2006 | 02:38 AM
Doobie77's Avatar
Doobie77
I changed to the S&S 510 gear drive cams. After 3000 miles on my 06 Heritage Classic I already had wear on the cam chain tensioners. Big time torq increase with the 510 cams!! (had it dyno'd)
Good luck
Old 10-01-2006 | 10:53 AM
Fatboy2's Avatar
Fatboy2
I am guessing there is a DIY post for the procedure to disassemble and most importantly, correctly reassemble.
ORIGINAL: xxxflhrci
Old 10-01-2006 | 11:05 AM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL: Fatboy2
ORIGINAL: xxxflhrci
You can find it here...
http://www.harleyhog.co.uk/index.htm
Old 10-01-2006 | 02:46 PM
Fatboy2's Avatar
Fatboy2
Thank You
ORIGINAL: xxxflhrci
ORIGINAL: Fatboy2
ORIGINAL: xxxflhrci
Old 10-01-2006 | 05:16 PM
glide's Avatar
glide
I don't think you will find many sections still in operation on that site.
The MOCO has just about shut him down completely.
Old 10-01-2006 | 05:36 PM
dawg's Avatar
dawg
The two sections that cover the cam chest are still in operation, those being the big bore and cam swap and then one of the tickers that you can see the shoes (distorted) in the picture of the ticker. Best to have yourself a manual also.
ORIGINAL: glide
fastflooge
06-28-2018 07:57 PM
1peter
Exhaust System Topics
06-08-2009 03:30 AM
Sicilian69
04-19-2008 04:00 PM
genedjr
07-30-2007 11:19 PM
jgallemore
06-03-2007 12:30 PM
Quick Reply: Cam chain tensioner Noise?
