2010 RK 6 speed transmission
Bought a 2010 RK 6 speed new and have 12 k miles. The transmission has an unbearable clunk when going from neutral to first. Also up thru 2 & 3rd. Have tried Amsoil, Spectrol and dealer has installed a SE compensating sprocket.
Nothing has helped one bit. Transmission shifts fine, no problem finding neutral, etc.
Anyone have similiar problems and a solution? It's embarrassing to ride. My previous 2001 RK with a 5 speed and 120 k miles never had this problem.
kingtut
kingtut
I had repeated problems with a new bike some years ago (not a Harley) and the dealer finally diagnosed warped clutch plates, which were dragging slightly, messing up selecting first gear. When on the move it was sweet as a nut. Changing the warped plates cured it.
Another possibility is simply clutch adjustment. That can certainly be a problem on older models. But we would hope the dealer already checked that....
bicpd3527
13
01-28-2019 01:25 PM
nthnymerritt
07-04-2015 08:26 PM
2010, 2011, davidson, explained, good, harley, mods, problems, redline, speed, sportster, tranny, transmissin, transmission, transmition
