OK, need a stronger clutch but have to be able to pull the lever !
well crap crap and double crap. Since my engine build this summer, my clutch slipped at the top end. THOUGHT I had the answer in the form of a new Barnett pressure plate that was SUPPOSED to be about 20% stronger than stock. Plate was thicker than stock for sure. Finally got around to swapping it out today and MAN O MAN I could barely pull the clutch lever with my old feeble arthritic hands (didn't realize I was such a weakling dammit).
So for now I had to put the stock pressure plate back in. What are my options for a stronger clutch while still being able to pull the levefairly comfortably? I'm somewhere around 100hp/100tq.
I use a pre 03 clutch spring with it. Much softer than the SE spring, but stiffer than the 06 and up spring.
steveh326,
Install a reduced effort clutch actuator and ramps...Harley, Burley Brand and others make a kit. Regardless of what spring you use, the easy pull kit will reduce your required force significantly.
http://www.burlybrand.com/clutch/index.aspx
- Kits with ramps change the clutch "throw" where it takes more lever travel to engage the clutch and visa versa..
- HD Reduced Effort Kit includes the ramp/ ball, Burley Lite Clutch does not.
- HD kit includes a lighter clutch spring which you can toss..
I picked one in the middle (the 37871-98A) and have no problems now. I did notice a bit of an increased pull, but it is not anywhere near what the SE spring feels like. Where I really notice it, is in heavy traffic when I am working the clutch a lot, other than that, I forget I even changed it.
Here's a list of some springs with some tension specs. (borrowed from iclick) Note the Police spring tension spec (in Bold) is one step lower than the SE
37882-06 (117 KgF) 2006-88”, 2007 thru 2010-96”
37871-04 (135 KgF) 2004-05 88” and 2010 Limited
37871-98A (145 KgF) 1998-2003
37807-03 (165 KgF) 2007 thru 2010-103 ”Police"
37951-98 (175 KgF) Current SE
VPC is a 20-30 minute job with no loss of fluid. This thing is bullet-proof. No fooling with springs, cables ramps, etc. Many heavy bikes, such as the TG are running the 84T. I run the 70T over an SE spring on a heavily loaded trike puling a trailer and never have any slipping problems. If my cat had a thumb....she could pull the clutch lever.
It simply replaces the ring over the diaphragm spring through the derby cover.
I know this is an old thread, but it's been winter here and so much ice have not been able to ride. Finally got around to installing the -98a clutch spring, and got some miles on the bike in the last couple days. so far I could not detect any slippage. I think this thing is the answer to my prayers... clutch seems to be holding, and clutch pull is not bad at all. I did drop out the mobil 1 when I changed the spring and replaced it with formula + just to play it conservative but I doubt that made much difference.
Many thanks to the folks that took time to reply here to give me some advice on my issue.
