Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Belt Tension
Old 12-23-2010 | 12:09 PM
Ozark Azz's Avatar
Ozark Azz
Default Belt Tension
I posted this in the softtail area and didn't get a response. Thought I would try here. I have a Heritage and a Rocker. I was doing the 5000 mile maintenance today on the Rocker and the belt tension specs got me wondering. What's the technical reason the Rocker & FLSTN belt deflection specifications are so much tighter than other Harley's. Deflection calls for 5/16-3/8 in. with rear wheel in air. Other bikes call for 11/16-3/4 in. Seems awfully tight. Thanks. Ozark Azz
Old 12-24-2010 | 07:19 AM
lowriderrob's Avatar
lowriderrob
Merry Christmas Ozark
Here' a link to a fairly detailed explanation.
http://www.epi-eng.com/rotorway_heli...elt_issues.htm
I know it says Helicopter, Rotor drive, but section #4 in the artical goes into detail about these Gates belts on Harleys
Old 12-24-2010 | 09:26 PM
jcanrun's Avatar
jcanrun
My 09 Road Glide has the 5/16 to 3/8 spec or something really close to that for all late model touring bikes. Street Glide has a 1/4 to ? spec because it is lowered. I think that when Harley went to the narrower belts than before, the belt tension specs increased (tighter).
Old 12-25-2010 | 07:27 AM
1flhtk4me's Avatar
1flhtk4me
I posted this in the softtail area and Other bikes call for 11/16-3/4 in.
What other bikes?
My old 'o6 Road Glide and my new '11 Limited are about 1/4-3/8".
11/16-3/4" is way to loose.
Old 12-26-2010 | 12:00 PM
Ozark Azz's Avatar
Ozark Azz
lowriderrob, thanks, and Merry Christmas to you. The article was very informative and shows the danger of an under tensioned belt and why preload would change for different suspensions and even horsepower used at a given time. Thanks Again. Azz
Old 12-26-2010 | 12:06 PM
Ozark Azz's Avatar
Ozark Azz
jcanrun, thanks for your response. I went to garage and checked the suspensions on both bikes. The rocker does have a narrower belt (over 1/8") and the suspension doesn't move unless you hit something really hard. My kidneys can attest to that. With a firmer suspension you can expect less travel and it appears that the tighter you can run a belt, the better (within reason). The Heritage suspension really is bouncy in comparision, but rides much better. Thanks, Azz
Old 12-26-2010 | 12:17 PM
Ozark Azz's Avatar
Ozark Azz
1flhtk4me, thanks for taking time to respond. I have a service manual with the 2008 bike, but only an owners manual for the 2006. I referenced my manuals again and 2006 owners manual wants it on the jiffy stand with a rider sitting in seat. The service manual for 2008 models calls for bike on jiffy stand with no rider. I didn't catch that difference until now. Or the bike can be upright with rear wheel in the air for a greater deflection. Thanks to you guys for helping me understand. Azz
Old 12-29-2010 | 07:19 PM
1skrewsloose's Avatar
1skrewsloose
Excellant info on this post. Thanks, kinda like to know the "why" rather than just accept, waay cool!! Great question and great answers.
mmesa005
08-07-2017 07:50 PM
509Rider
06-16-2015 08:25 AM
shrini23
11-11-2014 12:01 PM
pturner
06-24-2011 12:37 AM
Ozark Azz
12-22-2010 01:41 PM
Quick Reply: Belt Tension
