Is there a clutch "interlock" on the perch?
11-26-2010, 10:33 AM
I have a '10 Xbones and am doing my winter mods using my old '01 softail manual. Things have changed. I was planning on installing a foot clutch. My first step was to wire my stock bars. When I went to reinstall then, I realized there was a small spring-loaded switch diretly under the clutch lever. Does anyone know what the switch does?? Am I out of luck?
11-26-2010, 10:41 AM
I would assume that is the kickstand switch, but my bike is an 02 so it does not have one either.
Drew
11-26-2010, 11:46 AM
Yes the newer bikes have a clutch interlock switch that won't allow you to start the bike without having the clutch pulled in if it's in gear.
11-26-2010, 11:58 AM
Quote:
Originally Posted by
dawg
Thanks Dawg. If I start it in neutral, can I bypass the switch?
11-26-2010, 12:06 PM
I would think you should be able to. I can start my bike in neutral even with the switch.
11-26-2010, 01:56 PM
dawg
You're the man!!!! That was the answer I was hoping for.
Now for the foot clutch!!!!!!!!!!!!!!!!!!!!!!!!!
Max Headflow
Milwaukee Eight (M8)
38
11-10-2020 08:17 AM
onebad2
10-03-2013 08:58 PM
labou1
The General Motorcycle Forum
02-18-2009 06:15 PM
Wally
02-19-2008 12:28 PM
bikereef
10-29-2007 10:43 PM
