Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Help! My clutch won't release!
Old 11-19-2010, 09:40 PM
Moonrider's Avatar
Moonrider
Moonrider is offline
Unhappy Help! My clutch won't release!
I need some help! I had to replace the stator on a 03 wide glide and now the clutch is hanging up. I adjusted dthe freeplay and checked everything is working fine except that when I pull in the clutch, the bike feels like it is still released. With the lever pulled, the spring is flexed and I get about 1/4" of movement still feels stuck in gear. I removed all freeplay in the cable and still hangs up. Cannot move the bike in 1st. gear with clutch engaged. I tried to start the bike with the lever pulled and the scoot just lurched forward. Now the weird part. If I put it in 3rd. 4th. or 5th. Does'nt seem to hang up at all. This is not the first stator I have replaced (lots) first one with this problem. One other thing, the bike belonges to my big brother-inlaw and he want's it by Sat. So there you have it. Anyone out there have any Ideas?
Thank you in advance!
Old 11-19-2010, 09:46 PM
1931jamesw's Avatar
1931jamesw
1931jamesw is offline
Maybe it need adjustment at the derby. Have you tried that?
Old 11-19-2010, 11:25 PM
Moonrider's Avatar
Moonrider
Yep. No difference. I even screwed the adj. screw in to take up any freeplay and still hangs up.
Thanks for the reply.
Old 11-19-2010, 11:53 PM
NickD's Avatar
NickD
NickD is offline
>>I tried to start the bike with the lever pulled and the scoot just lurched forward.<<
It sounds like you clutch plates are sticking together. You're on the right track, just keep doing it. Start the bike with the clutch in and when the bikes lurches forward hit the brakes hard. Eventually the clutch will break free. Some guys do it just by rocking the bike back and fourth. (In gear, clutch lever in.)
Old 11-20-2010, 12:00 AM
Scratt's Avatar
Scratt
Scratt is offline
After you took up the slack did you back it off 1/2 to 1 turn back out and set it?
You have to have slack in the cable to set the push rod adjuster correctly
Old 11-20-2010, 01:04 AM
jackstrr's Avatar
jackstrr
jackstrr is offline
possibly cluch plates have worn groves in the cluch hub.
Old 11-20-2010, 06:29 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Maybe something happend to the ramp on the other end.
Old 11-20-2010, 08:23 AM
big cahuna's Avatar
big cahuna
big cahuna is offline
Was it working fine before you replaced the stator? if so then its definitely an adjustment issue. I had the ***** in the trans cover fall out of place with my '93 evo, and it took very little work to get them back where they belong . Did you loosen the clutch cable adjustment before you adjusted the clutch pack adjustment?,..
Old 11-21-2010, 05:19 PM
Moonrider's Avatar
Moonrider
First. Thanks to all that replied and offerd different ideas to help solve my problem. As it turns ou NickD was right on. It took a while (20mins) of starting and easing the clutch with the brakes and it finally freed up. I guess with the clutch pack settin aside awhile while doing other things on the scoot and time constrants (about 3 weeks) the discs were stuck either by them drying out or just with the oil on them. I didn't think it would hurt them settin in a empty container with a rag covering it? After I got it all back together and had the problem I did not think of the obvious. After all this is not the 1st. time I have replaced a stator or worked on a clutch pack. Oh well I learn new stuff all the time. Anyway, thanks again for all you help!
Dave R.
p.s. Maybe it was the kind of primary oil or the burned up stator mixing with the oil.
Old 07-25-2022, 08:06 PM
Mlzconstruction's Avatar
Mlzconstruction
Mlzconstruction is offline
Stage I
Default Similar issue
So I'm having a similar problem. Only difference is that I can't shift out of 1st. Does this change any part of your advice?
Quick Reply: Help! My clutch won't release!
