inner primary seal
inner primary seal
I have a 07 deluxe and just recently started to notice oil collecting under the bike. I checked the primary drain plug and replaced the oring on the drain plug. I believe the inner primary seal is bad as the oil seems to be coming from that area. My question is how much do you think this would cost to have a shop repair.
I have the same problem right now on my 2004 EGC. I replaced the main seal and the jack shaft seal. It still leaked. I am now convinced by what I have found it is the main shaft seal on the transmission. You may want to put some red transmission fluid in your primary and rise it a little and see if that is what is leaking or if it is the transmission.
Tranny fluid will run down then collect under primary before dripping to ground.
I use Redline so it was easier to trace.
get the baker output shaft bearing upgrade which doesn't incorporate the race. i had the same leak, caused by the race walking inward. so i ended up even pulling the entire primary and gearset replacing all bearings and seals on the outpt shaft and primary too. it will be spendy if you have someone do the work. my seals were bad. if i looked behind the primary up at the front pulley, i could see where the leak was coming from. it would be easy to just replace the primary gaskets and drain plug o-ring and think it's fixed. that's what i was about to do, but a good friend was there and he pointed out to me where the leak was coming from.
+1 I never do the "use the gasket twice" on that job. Too much of a PIA to do it twice. Same for those inner primary sealing fasteners.
