larger sprocket
RE: larger sprocket
I did the math on it this year when I had the primary off, and decided it wasn't worth it. I was looking at changing my engine double tooth compensating sprocket, not the drive belt sprocket.
1. You gain higher highway speeds at lower rpm, but you have to gear down more to pass, or when you are heavy.
2. You only gain a 7% reduction in revs with a two tooth change, and I'm never that close to maxing out my comfortable rev's.
3. Your bike has the potential to lug more in quick reduction of speed.
4. A wrench who I really respect told me that by using a 6 speed, I would not lose the rev's in lower gears, and I would get lower rev's at highway speeds.
That's why I didn't do it
HDF Tech
06-19-2011 05:50 PM
