shifter shaft removal
With early kits, there was a clip to hold the top end of the mid-shifter on the trans side, and a chrome cap to cover the end of the shaft where it exited the outer primary.
Later kits did not have this, and you either had to improvise, or remove the inner primary, remove the old shaft, and upon reassembly fit the little blanking cap into the
bushing hole that was, accordingly, vacant.
If you can turn a wrench, you would want to do the primary off deal anyhow, and completely remove the shaft, as it is the best look, and most functional result by far.
The gasket between the inner primary and engine does tend to leak if not replaced each time, so watch out for that.
The outer gasket seems very resilient, and can often stand being used a few times.
The shaft sits inside the casting on the inner primary. Should just sit there. FWIW, I would leave the set up you have now if you plan to sell the bike so the buyer has the option of going back to mids. Also, if you do remove the cover or inner primary you will need sealing fastners as they are only good once. You will also need all of the tightening sequences and torque values so be sure to get a service manual. Don't forget loctite and a primary sprocket locking tool as well.
My SM says replace the sealing fasteners and a HD master tech has told me they stretch when torqued and should be replaced. That's my story and I'm sticking to it.
It is possible for a bolt to stretch when torqued, and sometimes both desirable and necessary.
This is not the case here though.
There is nowhere near enough tension to elongate the bolt.
Your so called master tech lives in a dream world of mis-understanding, applying poorly understood information to non relevant situations.
The manual will always say to replace any sealing device, whether a seal, or a gasket, or in this case, a sealing bolt.
This is to protect themselves.
Some post that when you pull the inner primary, you should replace all the seals, etc,etc.
Certainly the SM states the same.
But there is really no need.
When you have a higher level of understanding, you are not subject to blanket SM statements.
When you know very little, you are unable to discern accurately, and so must accept blind statements.
A little restraint in attempting to burden others would be nice, however.
bigdaddyj
10-31-2007 06:08 PM
