Primary chain lubricant
I have an '03 Dyna Lowrider, I changed the Primary lube today, the book says to put in 26 oz. , then quote " The primary chaincase lubricant level is acceptable when lubricant is visible in the bottom of the chaincase with the motorcycle standing upright" I poured all 32 oz. of fluid before I could see it. It is still about a 3/4 of an inch below the bottom opening. I assume this extra 6 oz. is ok, especially since 26 oz. was not visible. Am I correct on this assumption? Yes, the bike was upright.
Thanks for your reply.
RE: Primary chain lubricant
32 oz. = 1 quart. I swapped out my stock grey primary cover for a chrome one @ 800 miles (bike was getting close enough for the 1,000 mile primary lube swap anyway) and used a full quart of HD Formula+ in the primary...service tech said it would be fine so I went ahead and put the whole quart in. Since then I've put over 250 miles on my '06 Standard and have had no ill effects...no leaks/noises/clutch slips...nada!
ORIGINAL: HDWG
Mine friggin leaks if I put too much in, including the correct level. While putting a new gasket on my inspection cover, where the leak is coming from....HD in Greenville the tech told me to put alittle less.....
During my last oil change I used the RedLine MTL in the primary and put more than the called for 26 oz. however, I pretty much completely drained it whereas if you just let it drain sitting on the jiffy, it doesn't get quite all of it out.
