Removing inner primary
Answer
Hope you get a good answer here. I want to know this one. Since you need to pull outer primary cover off for the starter anyway, I am not sure why Harley did not put that hidden bolt thru from the primary side. I guess oil tank is no problem, just three page of the manual, 5 more specialty tools, seat,battery,drain oil, remove oil drain, ect....
Well, out shop mechanic does it, but he will not tell me his trick. i was not there when he took mine off so I don't know how he did it. When I removed the IP myself I pulled the oil tank which is a real PITA. Look at the starter bolts that have to come out from the right side of the bike. I could only see one with the oil tank there.
But there is a way to do it apparently.
Drew
Drew
Battery
Just to clarify, were is your battery in an 08 FXSTC, my battery is under the seat in the center of the oil tank and other then removing the negative wire for safety has little to do with getting at the starter bolts on an 04 Softail Deuce. I was assuming the problem here is the oil tank limits a persons ability to get a wrench behind starter. I have not pulled the rubber pad out of the bottom of the battery box but it did not appear you could reach thru the battery box Keep getting side tracked here but just out of curiosity should there be a strap on top of the battery in this Softail
Use a long extension with a ball end hex wrench. Also use a flashlight to see the screws.
If necessary:
You can remove the battery, remove the two screws at the top of the battery box, remove the nuts on the rubber isolators and wiggle the tank loose from them. You can now raise the tank about 3/8" for better access. Use a few wooden shims to hold it up.
If necessary:
