Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Removing inner primary
Old 08-15-2010 | 09:32 AM
2kids3pets's Avatar
2kids3pets
Originally Posted by ajayrk
Use a long extension with a ball end hex wrench. Also use a flashlight to see the screws.
If necessary:
You can remove the battery, remove the two screws at the top of the battery box, remove the nuts on the rubber isolators and wiggle the tank loose from them. You can now raise the tank about 3/8" for better access. Use a few wooden shims to hold it up.
This is exactly what I thinking, there has to be a way other then how its laid out in the manual.
OldWheels
EVO
05-19-2016 11:32 AM
Skeezmachine
10-31-2014 10:22 AM
Alain
05-25-2012 05:17 PM
JohnFlorida
EVO
07-05-2011 06:27 AM
bigsofty
05-07-2010 10:05 PM
Quick Reply: Removing inner primary
